2021-03-18 3:07 AM
We tried to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD.
But not found any effect on measurement reading.
If you share some input for way to use VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, then it will be very useful.
2021-08-19 11:00 AM
This theshold says to ignore the range if the signal is so low that it's likely to be a false target.
The coverglass returns a number of photons. (No glass is 100 percent transmissive.)
And if those few photons were to trigger a range, you would get a false result.
So this parameter is generally set to 1.5 times the number of photons the coverglass refects.
That way you only get a target when there really is one.
2021-08-19 11:00 AM
