How to use two sensorTile simultaneously
‎2021-05-07 5:25 AM
I have loaded the SENSING1_V4 firmware on my STEVAL-STLKT01V1 sensor and I am using it with the ST BLE Sensor iPhone app, saving the data on the SD card.
Since I would like to use two sensors simultaneously, I wondered if there was a way to do this using just one mobile phone.
Thank you,
Chiara
- Labels:
BLE Mesh
‎2021-05-07 7:35 AM
Hi Chiara @CRoma.1​ ,
unfortunately you cannot interface two Sensortile simultaneously on the ST BLE app on the same smartphone.
There is a smartphone app, the STBLEMesh, that can manage different devices over BLE mesh (here some further details), but in the default supported platform there isn't the Sensortile.
You might think to modify the BlueST-SDK code, but I believe it won't be an easy job...
-Eleon
‎2021-05-07 7:35 AM
-Eleon
