2023-01-24 09:21 PM
I am using STS35 DIS and Nucleo-WB55RG board and wants to know how to get temperature readings from the sensor. I am using STM32CubeIDE for programming. It would be helpful for my learning and proceed with my project. if you share some example coding for this.
2023-01-26 03:03 AM
Hello @BT.2 ,
First of all, please check sensor pins : (SCL / SDA)
Finally, open STM32CubeMx and start the configuration. :D
Foued
2023-01-26 03:03 AM
Hello @BT.2 ,
Foued
2023-01-27 01:30 AM
Thank you
2023-01-27 01:35 AM
You are welcome and welcome to the Community ;)
Hope my answer helped you!
When your question is answered, please close this topic by choosing Select as Best.
This will help other users find that answer faster.
Foued
2023-01-27 07:47 PM
Maybe this example (I2C_Master.c) and related STTS751 temp sensor in the B_ANALOG_ENV folder may help you for component bringup with I2C GPIO SW bit banging.
