How do you merge the C driver code from ST with the algo code?
‎2022-10-03 11:07 PM
‎2022-10-03 11:40 PM
The flow is the follow: you can use AlgoBuilder firmware template using STM32CubeMX and X-CUBE-ALGOBUILD and X-CUBE-MEMS1 packages. The drivers are taken from MEMS1 package and there are quite a lot of sensor already supported.
