2020-08-16 02:48 PM
I wrote some patterns for three-axis state machine based on MKI134V1. Now I need to import that patterns into six-axis state machine based on MKI196V1. I used standart button "load" but nothing worked. I can't find user manual with examples six-axis state machine like I found for three-axis . If you share this manual or help to solve my problem I'll be grateful.
P/S Sorry for my English
2020-08-18 06:55 AM
Hi @NAndr.1 ,
when you said you wrote the patterns for the three-axis state machine, do you mean you are trying to load a .fsm file in Unico?
2020-08-18 03:28 PM
Yes, I use Unico GUI for work.My three-axis patterns has ucf form. I used to load them in "Load /save congiruration" tab. I had understood thats patterns for 6-axis state machine has .fsm form. But maybe exist another way to "upgrade" old patterns and make them work with 6-axis?
2020-08-19 01:51 AM
I'm sorry, but the configuration files are too different to be used with both sensors.
you can find some examples of Finite State Machines for the LSM6DSO (MKI196V1) here: https://github.com/STMicroelectronics/STMems_Finite_State_Machine/tree/master/lsm6dso
and the application note that explains how to implement it here:
may I ask you what does your pattern do?
