Hi, I want to know how the ILPS22QS sensor works with specifc reference to the Qvar functionality. Where could I find some documentation in order to study this device? I've found a technical document but there are few general informations. Regards.
Zenk91
Eleon BORLINI
Hi @Zenk91​ ,
For a general explanation of the Qvar principle, you can refer to the AN5755 application note.
For a more specific explanation on the Qvar sensing embedded in the ILPS22QS, you can refer to the AN5764 application note, from p.35.
Hope this can help.
-Eleon
5 REPLIES 5
Eleon BORLINI
Hi @Zenk91​ ,
Hope this can help.
-Eleon
Zenk91
Hi Eleon Borlini,
Thank you very much for your answer, I will read these application notes. Could you clarify me the following doubt, please? Fundamentally the Qvar functionality makes a voltage detection induced by the presence of the electrostatic field? Thank you very much.
Regards.
Good morning,
I opened the second link (AN5764) but it shows always AN5755 application note, maybe that's an error? Thank you.
Eleon BORLINI
Hi @Zenk91​ ,
This is the correct link for AN5764, you can find it online:
https://www.st.com/resource/en/application_note/an5764-ilps22qs-dual-fullscale-absolute-digital-output-barometer-with-embedded-qvar-electrostatic-sensor-stmicroelectronics.pdf
That's correct, it can detect a contact or no-contact voltage.
-Eleon
Zenk91
Thank you very much, your help was very precious!
Fabio.
