Can I manually select the training algorithm/filters and features (peak-to-peak acceleration for example) while creating a decision tree with Unico?
Eleon BORLINI
Eleon BORLINI
Sure, if you use Unico you will be prompted to select the filtering and the features you want to apply to the dataset. You can find more about the filtering and the available features at THIS link.
Eleon BORLINI
