Write data file to sdcard using fatfs module and spi interface.
sayali more
Posted on April 05, 2017 at 07:10
Hello i m trying to write data file to sdcard using fatfs module and spi interface.. bt somehow i m not able to write to sdcard.. can anyone please suggest the way to do it?
4 REPLIES 4
Gerardo GALLUCCI
Posted on April 05, 2017 at 20:40
Is this a question related to some connectivity module or IC? Please argument your issue
Posted on April 10, 2017 at 14:12
actually, I m trying to externally interface sdcard using SPI interface, the sdcard slot is used for external interface, but the using of FATfs library i am not able to find any linkage o FATFS lib and spi(where my sdcard is connected in hardware), does FATFS have any coniguration made for spi  interface...
Posted on April 10, 2017 at 17:56
Are you talking about SPWF04S module? This forum is dedicated to WiFi modules...
Posted on April 10, 2017 at 18:06
Learn to frame your questions with enough context so people other than you, with no psychic insight into the boards and chips you are using, stand some chance to understand wtf you are doing and with what...
