Which WiFi module is best fit to use with STM32F103C8T6 controller?
vishweshgm
I want a project to be done urgently using STM32F103C8T6 controller using CUBEMX. This project has a requirement of sending some measured data to cell phone using mobile's hotspot (and not using internet. Basically I need to send it through TCP/IP). I tried using ESP8266 but couldnot find the proper libraray implementation for the same that I can use easily. Can you guys recommend a best wifi module that I can use with this controller and get the project ready soon. Appreciate the library links in the answer description. Cost of the module does not matter.
Aydn22
Which one did you use
