updated UM1755 doc?
philippe1
Posted on February 03, 2015 at 08:49
Hi everyone,
I was wondering if there is an updated version for the UM1755 which (partially) describes the commands available for the BlueNRG chipset. I can't find decoding scheme for the VS HCI events for example.
Thank you.
11 REPLIES 11
namoaton
Posted on January 13, 2016 at 19:43
Could you please help me with this frame ?
Thank you.
04 ff 03 01 00 01
Posted on January 15, 2016 at 12:40
Dear Customer,
here below the description:
0x04- Event type
0xff - HCI_VENDOR;
0x3-Parameter Total Length;
0x01,0x00 - (0x0001 little endian) - Evt_Blue_Initialized
01 - Reason_Code ->Firmware started properly
This event occurs when the BlueNRG-MS firmware is started normally, it gives a Evt_Blue_Initialized event to
the user to indicate the system has started (with Reason Code 0x01).
GM
Thank you.
04 ff 03 01 00 01
