Wei Lu
SPWF04SA always return ''Hardware Failure''
  • August 10, 2017
  • 1 reply
  • 583 views
Posted on August 10, 2017 at 09:47
Hi ST,
Recently I try to enable AP or station mode on SPWF04SA wifi module,
I connect it with my PC via UART and I can see some feedback on terminal on my PC.
The question is, even though I can command SPWF04SA with its own AT command,
it always shows '+WIND:5:WiFi Hardware Failure:5', and I cannot see what's wrong with my board.
I followed this site to command SPWF04SA,
http://elektronikab2b.pl/technika/32973-spwf04sa-miniaturowy-modul-wi-fi-z-oferty-stmicroelectronics---przyklady-zastosowan♯.WYvNzFUjHIW
Please help me.
Wei Lu
#hardware-failure #spwf04sa
    1 reply
    Rakshith KR
    Visitor II
    February 5, 2018
    Posted on February 05, 2018 at 12:38
    This is possibly due to the power...
    I believe you might be powering ON through your USB port which may not give sufficient current to power ON the module,
    Use the external power ...!
    It should solve your issue...
