2018-09-06 5:03 AM
Hello everyone,
We are using the SPBTLE-1S in order to impelement an SPP protocol. We are using both the Chat and Security example project. Everything works fine except pairing request.
When we try to connect to device after a reboot, there's a pairing request and we must re-input the pin code. Is there any way to remember the last device connected (or a list) and skip the pairing request?
Any suggestions?
2018-10-02 1:15 AM
Solved.
In case someone has the same problem: remove the aci_gap_clear_security_db() function from code.
