S2-LP RAW DATA OPTION
melihakalin
In different project with S2-LP we want to read raw the for understand and anlyze any data of the communicate between 2 devices.
Are we take tke raw data?
Is the S2-LP support E527 standart?
Melih
6 REPLIES 6
Peter BENSCH
Welcome @melihakalin, to the community!
very interesting question - if we knew what you mean by E527 standard. Would you please describe this in more detail?
/Peter
Hİ Peter,
Thanks for a feedback. E527 is a RF standart for ISM band.
Another way  if the S2-LP don't have an E527 encoder, we can encode the E527 standart but we have an issue the read raw data on the S2-LP. Are we read to all raw data of the S2-LP's read?
Peter BENSCH
If this is a standard, you should be able to find it with your favourite search engine. As this is not possible for me, I would appreciate an URL.
Dear Peter,
Ignoring the standard process, How can we read the raw data of S2-LP's read?
Best Regards
Melih
Peter BENSCH
It is probably possible to read the raw data, but I am currently unaware of any details. If you can specify your standard more precisely, it might be possible to check whether this can be implemented with the S2-LP.
/Peter
If the S2-LP give us a raw data, we can decode with MCU it's not a problem for us. the main problem was we can't take the raw data
Best Regards
Melih
