2022-08-14 4:24 PM
Hello ST,
@EMECH
I am using BLE_MeshLightingProvisiner sample project. We try to trace the RSSI value from the below mentioned function::
BLEMesh_NeighborRefreshedCallback(const MOBLEUINT8* bdAddr,
MOBLEBOOL provisioned,
const MOBLEUINT8* uuid,
MOBLE_ADDRESS networkAddress,
MOBLEINT8 rssi)
>>> NeighborRefreshedCallback function RSSI value 29
BLEMesh_CustomBeaconReceivedCallback(const MOBLEUINT8* bdAddr,
const MOBLEUINT8* data,
MOBLEUINT8 length,
MOBLEINT8 rssi)
>>> CustomBeaconReceivedCallback function RSSI value is 2
Both values are constant and not changing with LPN device displacement.
Is there any configuration require in project to get the right RSSI value?
Note: Purpose of this test to get the distance b/w prvn and lpn node in cm.
Thanks!
Best Regards
Deepak Aagri
2023-01-20 2:19 AM
@Deepak.Aagri have you found an solution for this problem of constant values?
I have the same problem and the RSSI Value is constant 29 and not changing at all on he NeighborTable.
