no stm32 target found while connect st link v2 to target
srikanth
we are trying to program a hex file by using st link v2 programmer in cube programmer getting follow error.
no stm32 target found.
also I updated the firmware.
the target board is working with another st link.
from not working st link we are getting TCK but TMS not getting.
may be what is issue ?
4 REPLIES 4
Uwe Bonnes
Chief
Tripple check wiring, try connect under reset, try other debuggers or debug-programs for the stlink.
The failing ST-LINK is a dud?
Could be damaged at connector or cable.
Try a lower connection speed.
What type of STM32?​
thank you for reply
we connected with 240kHz low speed only.
cable is working fine.
we tried with stm32h750 MCU.
here which connector we need to check ?
thank you for reply
we checked with other stlink programmers and working fine.
we tried under reset mode only and all wiring has fine.
