Make S2-LP talk to nRF905
Witek
I have a need to make the S2-LP communicate to an existing RF system which is based on the nRF905. From the reading I have done it looks like it should be possible.
Does anyone have any suggestions on how to configure the S2-LP to do the job?
Witek
6 REPLIES 6
TIomm.1
I am struggling with the same problem. Have you by any chance figured it out?
I am trying to get S2-LP to receive nRF905 messages. I managed to achieve transmission in the reverse direction (nRF905 receiving S2-LP messages), but am struggling with this one. I have configured the nRF905 to work at the frequency of 868.2 MHz (CH_NO = 0b001110101) and set the S2-LP to work at 867.995564 MHz.
I have read here: https://devzone.nordicsemi.com/f/nordic-q-a/47122/nrf905-preamble (was it also your thread by any chance? :D) that the preamble transmitted by nRF905 is 0x055599 (already Manchester encoded), and so this is what I set my S2-LP's SYNC value to, hoping that it would pick up on the transmission. I also use the same parameters as mentioned in the forum thread I linked. When using the S2-LP DK GUI I can see that I am receiving transmissions from the nRF905 but the payloads are all wrong/mangled. That is if I set the sync word length to 0 (ignore it), if I set the sync word to 0x55599, I get nothing.
Do you have any tips on what I may have missed? Modulation method maybe?
Any help would be tremendously appreciated.
Thanks in advance,
Tony
Winfred LU
Maybe it is because the data is Manchester encoded?
Try to enable Manchester coding for data by: setting '1' to the MANCHESTER_EN bit in PCKTTRL2 register.
Note that for S2-LP, Manchester encoding is only applied to bits following SYNC word.
RWate.1
I am struggling with the same problem. nRF905's documentation doesn't explicitly say which type of modulation to choose (it only says it's GFSK). Manchester modulation is enabled (although I also tried receiving nRF messages without manchester encoding enabled on S2-LP and with no sync word in order to perhaps see in the message payload the nRF905 preamble pattern). And when I set the sync word to 0x00055599, I get nothing :(
From what I read, the nRF905 transmits the following pattern as a preamble/sync word: 01010101010110011001, am I right that for S2-LP to match against this, I should set the sync word in GUI to 0x00055599 (SYNC0=0x00, SYNC1=0x05, SYNC2=0x55, SYNC3=0x99)?
That looks right. And the SYNC_LEN (in PCKTCTRL6) shall be 0x14.
Hi Tony,
Apologies for the late replay. I have not been on this project for a while. And unfortunately I have not been able to figure it out. I set up the S2-LP GUI the same as you (except for the frequency as I work on 433MHz). When transmittin from S2-LP i am albe to receive messages on nRF905. But, somehow how well I receive depends on the content of the message. For example, when I set the payload to all 0xE7 then the nRF905 receives some 40% of the messages. When I set to payload to all 0xAA, then the number is around 90%. Also, when I change a few bytes from 0xE7 to something else then all the following byes are mangled up.
When sending messages from nRF905 to S2-LP, then then messages are received (at some 50% loss) but the data is all wrong.
Have you had any success since your post?
Witek
Hi Winfred,
I am unable to make the 2 chips communicate reliably. Can you please share information on how to configure the S2-LP? The nRF905 is very inflexible as far as configuration goes.
Witek
