I can't login to the webinar. I keep receiving the Login Failed. Please try again. reply of the page with the link. https://event.on24.com/wcc/r/2733877/E2ED4B3A3CB368C3F1C872C36D697E5B Best regards, Leonardo
lhmm
15 REPLIES 15
Hello Ons.
As per your indication the login with indication of previous registration failed, and if I fill the register form I get to access to the area.
Is this normal?
Best regards
Hi Ihmm,
No it is not.
After this registration, did you try to login again ? Did it work or not ?
Best Regards,
Ons.
Hello Ons.,
First I tried again using the usual method which is the use of the link "already registered". Failed
Afterwards I filled again the fields to "register now", _and accessed
the area directly_. Not necessary to do anything else _just to clicked
the "register"_ button/command.
Best regards,
Hi Ihmm,
It is really a bizarre behavior. The link "Already registered" should work. I tried with several email addresses and it works perfectly.
Best Regards,
Ons.
Hello Ons.,
_This time I tried again with the "already registered" link and got in_.
But _only now and not before_. In case you require further details from
my part to help you troubleshoot what was wrong feel free to request.
Best regards
Hi Ihmm,
Very good. So, I suggest that there was a problem with the email address added at the beginning (maybe a miss-typing or something like that) !
In case the problem is solved, Can you please mark the question as answered and choose the best answer for you?
Best Regards,
Ons.
