2018-11-05 02:11 PM
2018-11-07 09:00 PM
You can refer to following App Notes. The AN4819 talks about Balun layout etc
The device requires standard 2.4GHz Bluetooth Antenna
Refer to following documents
AN4819: PCB design guidelines for the BlueNRG-1 device
AN5187: BlueNRG-1, BlueNRG-2 improving robustness
2018-11-08 06:44 PM
alok,
Thanks for your answer, the documents are very interesting and I'm going to check on them, but I need info about the the best PCB antenna design for the blue nrg, type, dimmension, pcb material, pcb thickness, etc.
Again, thanks.
ANDRÉS FELIPE
