BlueNrg2M2sp Invalid HCI Command
MCV.1
Hi i am using Bluenrg 2 m2sp as network processor mode , Here when i sent aci_gatt_update_char_value_ext command , some times i getting getting invalid command response . may know the reason , if i get invalid response , shall i retry same command once .
Regrds
Manukumar
Winfred LU
I think those might be Invalid HCI Command Parameters (code 0x12).
Please check the differences between successful and failing commands. Possibly some parameters were incorrectly configured for the failing cases.
MCV.1
Thanks Winifred your response , i will check which command parameter are incorrect during the response
