BlueNRG-2 dual role configuration
Greetings,
I am developing a multi-slave configuration using a few BlueNRG-2 modules where the master would also connect to a smartphone and transmit data collected from the slaves (a tree network). Though a dual master-slave (central-peripheral) role is possible, the question is if this also possible to assign specific aci_gap_set_io_capability() and aci_gap_set_authentication_requirement() for each gap role in the master device? Say, IO_CAP_NO_INPUT_NO_OUTPUT for the slaves and IO_CAP_KEYBOARD_DISPLAY for the smartphone?
