BLUENRG-1 standalone
Nav Dev
Posted on March 30, 2017 at 13:05
Hi All,
I have question about BLUENRG-1, can it run as stand alone without another MCU?
If yes, I would appreciate very much if you could refer me to some references.
Nav Dev.
#bluenrg-1 #standalone-mode
4 REPLIES 4
Julien Tiron_O
Posted on March 31, 2017 at 11:05
BlueNRG-1 is a standard Cortex-M0 so it can run as a stand alone MCU.
All documentations and the SDK can be found in the following link:
http://www.st.com/en/wireless-connectivity/bluenrg-1.html
Julien
Posted on April 01, 2017 at 05:28
Thanks Julien for answering,
But you refer me to all the documentation of the chip, and i can't find any document related to how to set the bluenrg-1 as stand alone, and which components(hardware like another flash..) i need.
Can you please spasifi which document related to set as stand alone?
Nav Dev
Posted on April 01, 2017 at 09:57
Regarding the hardware part, you can have a look at the application note AN4819:
http://www.st.com/content/ccc/resource/technical/document/application_note/group0/5d/e4/cf/d0/5f/30/4c/38/DM00263000/files/DM00263000.pdf/jcr:content/translations/en.DM00263000.pdf
You won't need an external flash to run BlueNRG-1 as a stand alone MCU.
If your first step is to evaluate BlueNRG-1 then I recommend you get a BlueNRG-1 evaluation board:
http://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/communication-and-connectivity-solution-eval-boards/steval-idb007v1.html
With this board, you can have a good idea on how BlueNRG-1 works and start prototyping your own application.
Julien
Posted on April 02, 2017 at 11:48
Thanks a lot Julien, have a nice day.
