Ble Receiving Junk data
MCV.1
hi all
i am using blenrg2 m2sp chip as network mode. its operating as peripheral device and communicating with host controller through UART with 115200 baud rate .
I received BLE read characteristic request , i did not response till 1 second after that i getting some junk data , after that ble got disconnected . may know the reason . here attached logic analyzer images
Winfred LU
What would be the slave latency?
In case that the latency is OFF, the slave (BlueNRG-2) needs to respond within the connection event interval.
What would be the supervision timeout?
The link may be disconnected due to not receiving anything in supervision timeout period.
MCV.1
hi Winfred , sorry for delay replay , i am not fell well , during this time , i will check this and i will update on this , i need your support on this
MCV.1
hi winfred
slave latency =0
Conn_Interval=9216
Supervision_Timeout=-3071
but Supervision_Timeout showing negative value , in order to come aviod this i used below api
aci_l2cap_connection_parameter_update_req();
but still showing same response , can you suggest any other options for this .
