2020-07-07 1:01 PM
I am advertising and receive an incoming connection from an iOS App. This all works great.
In my disconnect_complete call back I enable advertising again with a call to ret = aci_gap_set_advertising_enable(ENABLE, 1, Advertising_Set_Parameters);
However advertising does not restart.
Also found that if I do a DISABLE and ENABLE again using the above call then advertising doesnt restart
2020-07-07 3:11 PM
Also found that a call to
ret = aci_gap_set_advertising_data(0, ADV_COMPLETE_DATA, sizeof(adv_data), adv_data);
while it is advertising works sometimes but often the advertising just stops completely.
