FRoub
Application note for L9663 PSI5 transceiver
  • May 28, 2019
  • 3 replies
  • 1231 views
Is there any possibility to have application note of a communication between a microcontroller and a sensor (magnetic angular position sensor in my case) using a l9663 transceiver. I'm a bit lost with all the infomation in the datasheet and I need a exemple.
    SDU.1
    Visitor II
    August 19, 2021
    Hi, do you find the answer? I have a similar application case. Going throuhg the datasheet, I think L9663 doesn't support a slave function at the sensor end.
    Winfred LU
    TEvan.3
    Visitor II
    October 2, 2021
    L9663 only supports the "Master End". There are no "general purpose slave chips" that you can add your own sensors to. Not that I can find anywhere at least.
