VL53L5CX High current draw in HP idle.
jspiller
I have a X-NUCLEO-53L5A1 board wired up with SDA, SCL, 5V, PWR_EN and GND only. The sensor works and current draw is as expected in its ranging and LP idle states. However, when first booted up it will draw a normal 6mA in its HP idle then will do its ranging and afterwards draw 22mA. There is ~15mA on IOVDD and 6.35 on AVDD. The same issue occurs when I set it to HP idle directly and give it nothing to run. Do you know the reasoning for why it draws so much current?
Thanks,
Jacob
Anne BIGOT
Hello Jacob,
Your question has been addressed internally. We will come back soon with an answer.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
