VL53L5CX gesture library older versions
SOsle.1
Hi, I would like to download older versions of the VL53L5CX gesture library (to be exact the 1.7 and 1.8 versions for cortex M4), but I'm only allowed to download the latest one (1.9). Is there any possibility to download these two versions?
Regards.
Stepan
Anne BIGOT
I will ask internally what can be done for you. But anyhow, what difference do you see between the 1.9 and the previous ones ?
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Anne BIGOT
