vl53L4CD GUI Not starting/opening
Afam_Nwokolo
i do not seem to be able to use the application gui for the vl53L4CD Nucleo board.
when i try and open the application i get this message. is anyone familiar with this issue?
5 REPLIES 5
Anne BIGOT
Can you let us know the revision of the package you are using ?
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
STSW-IMG027
I am unsure of the version because it is not listed, but it is the latest. screenshot shown below
Anne BIGOT
Thank you for your answer.
By clicking on the + in the left side of the 'STSW-IMG027' from your screen shot you can get the reveision.
Can you also let us know the version of the OS you are using ?
Afam_Nwokolo
I see,
my version is 1.0  - 15941
My OS details are
Edition Windows 11 Pro
Version 23H2
OS build 22631.4890
Your request was addressed internally.
In the meantime, can you try to uninstall the previous version, remove file in the installation direction and try to install it again ?
