VL53L1X Timing budget, Inter measurement period
MBabu.2
Hello, Is is mandatory to add inter measurement period function when I use the function Timing budget
John E KVAM
No - if you leave off the Inter-measurement period the sensor will range again immediately one after the other. Continuously is a perfectly fine way to operate.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
  • john
MBabu.2
Thank you @John E KVAM​ so much. I have another doubt
for the project , Since I wanted the VL53L1X to be more accurate I added a timing budget of 200 ms . I have 3 vl53l1x sensors and I tested each of them individually and its working perfectly and I am receiving the measurement once every 200 ms with timing budget 200 ms . Now I have combined all the 3 sensors and with timing budget 200 ms and programmed it to receive the data. I expected the results to be from all the three sensor every 200 ms(In a single string) , but am receiving the data every 600 ms(In a single string).Kindly help me with this issue
Thanks for the reply
