Our product uses the VL53L0X sensor. We are powering it from 3.3V. I notice the data sheet states ideal voltage rail of 2.8V. Is there anything we need to be aware of performance wise running at this slightly higher voltage? Thanks Leon
LWill.2
John E KVAM
No problem - with you asking or running with 3.3V.
3.3V is just fine.
The wider range voltage spec is for battery-based applications.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
LWill.2
I should have searched earlier. I see this is already answered.
Thanks.
John E KVAM
3.3V is just fine.
