2024-04-18 1:23 PM
Hello guys,
Im trying to learn about LoRa and else. Now, I am using an SubGHZ_Phy in stm32wl sdk. The problem is, when I am using vl6180x codes in while loop without sequencer, it does work! But, When I am trying to implement it with a 5 min util timer and a sequencer; VL6180x sensor does not work properly! It needs to measure a singleshot distance, in first start my readRange command returns 0. a
After first attempt, second and other attempt; it gives a value but I know it isn't true. I have already read aabput sequencer, I thought that my mcu turns off every peripheral and thats causes a problem like this. How can I solve it?
