Are ToF sensors available using a shorter wavelength than 940nm?
Miyaru
We're currently evaluating a VL53L1X sensor underwater (in a sealed housing) , but beyond 2m IR light is absorbed too much. A ToF sensor based on 532nm would achieve better results. Which options exist other than 940nm?
John E KVAM
Unfortuantely, not from ST.
And you are right about the 940nm light and water. One of the reasons we picked 940nm was there was less of at the surface of the earth. The water vapor in the upper atmosphere abosorbs 940nm light.
We have the VL6180 at 850nm, but it's specifically a short-distance sensor.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
