Is there any parameter in improve accuracy ? position way out about 30 miles
Options
‎2019-08-07 5:32 AM
So I played with the devkit and everything is ok..
I made custom board for a project and my position is way out by at least 30 miles?
I wonder if i am missing something or my antenna is not that good?
Options
‎2019-08-07 5:58 AM
Check any translation of NMEA DDDMM.mmmm to DDD.ddddddd forms, the 60 vs 100 division can result in many miles of offset. Arcminute about 1852m
Options
‎2019-08-07 6:27 AM
you are absolutely correct @clive... i was using a library i wrote long ago and indeed not doing the right conversion...
