device configuration tool is not generating
vaibhavi
The error messages says you should login. I suggest logging in and trying again. The myST menu is in the menu bar.
6 REPLIES 6
vaibhavi
i have also logged in many times
This happen to me when I am using a VPN with random ending point !
@Every endpoint change, i am required to re-log-in.
vaibhavi
now code generating tool is loading since 30 min Screenshot From 2025-02-17 12-26-07.png
eventually you can mark this as the solution - to help other developers
https://raimechaeropvtltd.slack.com/archives/D086W24BE8H/p1739794329899899
I tried to generate code by setting up pin assignments in STM32CubeIDE with reference to the following site for the generating code in stm32cubeide version 1.17.0.
