2024-11-19 04:09 AM
I have successfully ran and trained the models in modelzoo but I would like to use a larger model with yolov8 for higher resolution.
It was mentioned in another post that yolov5 and above is not compatible with ST chips at the moment.
In any case can how can I use a previous model let's say v4? The available models seem to be:
2024-11-19 07:07 AM - edited 2024-11-19 07:09 AM
Hello @dogg,
For the moment, as you said, only the following models are available for object detection:
