2025-03-08 10:19 PM
My question is same the title. I know that you have zoo model with custom training script to training or fine tuning based on provided model. But I have a new model, that is trained in other environment, I exported it to ONNX. How can I deploy this model to this board? Thank you.
2025-04-02 8:43 PM
2025-04-03 1:35 AM
Hello @Anhem,
Indeed, I forgot to answer sorry.
In my opinion, we still lack easy tutorial, starting from zero, integrating simple CNN and creating a small demo as you mentioned. We are working on it.
In the meantime, we already have some materials:
STM32N6 (DK board) getting started:
STM32N6-AI - AI software ecosystem for STM32N6 with Neural-ART accelerator - STMicroelectronics
Standalone or used with model zoo, you can find application example and source code for multiple use cases (image classification, object detection, segmentation etc).
In the docs, you can find how to integrate your own model manually, or you can find how to do it with model zoo here (image classification example):
N6, NPU and ST Edge AI Core documentation:
You can find most information here: https://stedgeai-dc.st.com/assets/embedded-docs/index.html
I would look in particular to these:
Then you also have X Cube AI for cube MX to generate a project for any MCU and integrate your model:
https://www.st.com/en/embedded-software/x-cube-ai.html#documentation
This document in particular: https://www.st.com/resource/en/user_manual/um2526-getting-started-with-xcubeai-expansion-package-for-artificial-intelligence-ai-stmicroelectronics.pdf
Have a good day,
Julian
2025-04-03 8:59 PM
Hi @Julian E.
Good morning.
Yes. That's good news. I am looking forward to see it. Please notify me when we have completed. I think that it is worth to build custom model from scratch, especially for beginnners.
Thanks for sharing other materials, I known these materials.
2025-05-26 12:53 AM
I deployed the model following this tutorial https://stm32ai-cs.st.com/assets/embedded-docs/stneuralart_getting_started.html , and the command executed successfully afterward.
python D:\stm32edgeai\stedgeai\2.1\scripts\N6_scripts\n6_loader.py
05/26/2025 03:09:42 PM __main__ -- Preparing compiler GCC
05/26/2025 03:09:42 PM __main__ -- Setting a breakpoint in main.c at line 125 (before the infinite loop)
05/26/2025 03:09:42 PM __main__ -- Copying network.c to project: -> D:\stm32edgeai\stedgeai\2.1\Projects\STM32N6570-DK\Applications\NPU_Validation\X-CUBE-AI\App\network.c
05/26/2025 03:09:42 PM __main__ -- Extracting information from the c-file
05/26/2025 03:09:42 PM __main__ -- Converting memory files in results/<model>/generation/ to Intel-hex with proper offsets
05/26/2025 03:09:42 PM __main__ -- arm-none-eabi-objcopy.exe --change-addresses 0x71000000 -Ibinary -Oihex network_atonbuf.xSPI2.raw network_atonbuf.xSPI2.hex
05/26/2025 03:09:43 PM __main__ -- Resetting the board...
05/26/2025 03:09:44 PM __main__ -- Flashing memory xSPI2 -- 14.625 kB
05/26/2025 03:09:46 PM __main__ -- Building project (conf= N6-DK)
05/26/2025 03:09:47 PM __main__ -- Loading internal memories & Running the program
05/26/2025 03:09:50 PM __main__ -- Start operation achieved successfullyHowever, when I run the following command, it keeps throwing an error.
python D:/stm32edgeai/stedgeai/2.1/scripts/ai_runner/examples/checker.py ^
More? -d serial:COM9:921600 ^
More? --input-file D:/stm32aibushu/input_data.npy ^
More? --perf-only -b 32
Creating AiRunner session with `Namespace(desc='serial:COM9:921600', batch=32, name=None, input_file='D:/stm32aibushu/input_data.npy', perf_only=True, io_only=False, with_data=False, show_tensors=False, verbosity=0, debug=False)`
ERR: No c-model available, use the --desc/-d option to specifiy a valid path/descriptor
E801(HwIOError): Invalid firmware - COM9:921600Would you happen to know how to fix this issue? Thanks!
