2025-05-24 1:47 AM
I want to deploy a PyTorch AI model on the STM32N6570. I have already trained the model and converted it to an ONNX file. I’m looking for a quantization, compilation, and deployment example or tutorial. The speech enhancement example in the STM32 AI Model Zoo Services doesn't match my use case. Although the input shape is the same, my model does not require any pre-processing. I only want to feed input data into the model and observe the output. Also, I would like to know if it's possible to perform deployment without providing a dataset.
2025-06-05 2:31 AM
Hello @llcc,
To do so you need to store your application and model in external flash (to avoid being erased on reboot) and create a FSBL to load your application and model to the internal ram on startup.
You can read more about that here:
https://community.st.com/t5/stm32-mcus/how-to-create-an-stm32n6-fsbl-load-and-run/ta-p/768206
We are also working on a tutorial for the DK board that should explain that.
Have a good day,
Julian
2025-07-10 11:22 PM
Recently, when I run the above command, I always get the following error. How can I fix this?
python D:\stm32edgeai\stedgeai\2.1\scripts\N6_scripts\n6_loader.py07/11/2025 02:22:16 PM __main__ -- Preparing compiler GCC
07/11/2025 02:22:16 PM __main__ -- Setting a breakpoint in main.c at line 125 (before the infinite loop)
07/11/2025 02:22:16 PM __main__ -- Copying network.c to project: -> D:\stm32edgeai\stedgeai\2.1\Projects\STM32N6570-DK\Applications\NPU_Validation\X-CUBE-AI\App\network.c
07/11/2025 02:22:16 PM __main__ -- Extracting information from the c-file
07/11/2025 02:22:16 PM __main__ -- Converting memory files in results/<model>/generation/ to Intel-hex with proper offsets
07/11/2025 02:22:16 PM __main__ -- arm-none-eabi-objcopy.exe --change-addresses 0x71000000 -Ibinary -Oihex network_atonbuf.xSPI2.raw network_atonbuf.xSPI2.hex
07/11/2025 02:22:16 PM __main__ -- Resetting the board...
07/11/2025 02:22:18 PM __main__ -- Flashing memory xSPI2 -- 38.913 kB
07/11/2025 02:22:19 PM __main__ -- Building project (conf= N6-DK)
07/11/2025 02:22:24 PM __main__ -- Compilation failed
07/11/2025 02:22:24 PM __main__ -- Start operation did not achieve successfullyThanks!
2025-07-11 5:14 AM
Hello
Can you share the `compilation.log` file ?
2025-07-13 7:57 AM
D:\msys2\msys2\usr\bin\make.exe all GCC_PATH=D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin BUILD_CONF=N6-DK
echo
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/arm-none-eabi-gcc build/Applications/NPU_Validation/Core/Src/main.o build/Applications/NPU_Validation/Core/Src/stm32n6xx_it.o build/Applications/NPU_Validation/Core/Src/md5.o build/Applications/NPU_Validation/Core/Src/system_clock_config.o build/Applications/NPU_Validation/Core/Src/misc_toolbox.o build/Applications/NPU_Validation/Core/Src/npu_cache.o build/Applications/NPU_Validation/Core/Src/mcu_cache.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbIO.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbMemRWServices.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbMgr.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiTestHelper.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiTestUtility.o build/Applications/NPU_Validation/X-CUBE-AI/App/ai_device_adaptor.o build/Applications/NPU_Validation/X-CUBE-AI/App/lc_print.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_common.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_decode.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_encode.o build/Applications/NPU_Validation/X-CUBE-AI/App/stm32msg.pb.o build/Applications/NPU_Validation/X-CUBE-AI/App/network.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_cipher.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_dbgtrc.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_debug.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_lib.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_lib_sw_operators.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_rt_main.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_runtime.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_util.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_sw_float.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_sw_integer.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ecloader.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/ai_wrapper_ATON.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/aiValidation_ATON.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/ai_io_buffers_ATON.o build/Applications/NPU_Validation/Drivers/BSP/Components/aps256xx/aps256xx.o build/Applications/NPU_Validation/Drivers/BSP/Components/mx66uw1g45g/mx66uw1g45g.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_xspi.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_bus.o build/Applications/NPU_Validation/Drivers/CMSIS/Device/ST/STM32N6xx/Source/Templates/system_stm32n6xx_fsbl.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_bsec.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_cacheaxi.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_cortex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_gpio.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rif.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_uart.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_xspi.o build/startup_stm32n657xx.o -mcpu=cortex-m55 -mcmse -mthumb -mfpu=auto -mfloat-abi=hard -specs=nano.specs -T./STM32N657xx.ld -L../../../Applications/NPU_Validation/../../../../Middlewares/ST/AI/Lib/GCC/ARMCortexM55 -lc -lm -lnosys -l:NetworkRuntime1010_CM55_GCC.a -Wl,--wrap=malloc --verbose -Wl,-Map=build/Project.map,--cref -Wl,--gc-sections -Wl,--print-memory-usage -o build/Project.elf
Using built-in specs.
Reading specs from D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/nano.specs
rename spec link to nano_link
rename spec link_gcc_c_sequence to nano_link_gcc_c_sequence
rename spec cpp_unique_options to nano_cpp_unique_options
COLLECT_GCC=D:\Stm32Cubbeide\STM32CubeIDE_1.16.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623\tools\bin\arm-none-eabi-gcc.exe
COLLECT_LTO_WRAPPER=D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/lto-wrapper.exe
Target: arm-none-eabi
Configured with: /build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/src/gcc/configure --build=x86_64-linux-gnu --host=x86_64-w64-mingw32 --target=arm-none-eabi --prefix=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw --libexecdir=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/lib --infodir=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/share/doc/gcc-arm-none-eabi/info --mandir=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/share/doc/gcc-arm-none-eabi/man --htmldir=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/share/doc/gcc-arm-none-eabi/html --pdfdir=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-mingw-wildcard --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-headers=yes --with-newlib --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/install-mingw/arm-none-eabi --with-libiconv-prefix=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/build-mingw/host-libs/usr --with-gmp=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/build-mingw/host-libs/usr --with-mpfr=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/build-mingw/host-libs/usr --with-mpc=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/build-mingw/host-libs/usr --with-isl=/build/gnu-tools-for-stm32_12.3.rel1.20240612-1315/build-mingw/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for STM32 12.3.rel1.20240612-1315' --with-multilib-list=rmprofile,aprofile
Thread model: single
Supported LTO compression algorithms: zlib
gcc version 12.3.1 20230626 (GNU Tools for STM32 12.3.rel1.20240612-1315)
COMPILER_PATH=D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/
LIBRARY_PATH=D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../arm-none-eabi/lib/thumb/v8-m.main+dp/hard/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/;D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../arm-none-eabi/lib/
COLLECT_GCC_OPTIONS='-mcpu=cortex-m55' '-mcmse' '-mthumb' '-mfpu=auto' '-mfloat-abi=hard' '-specs=nano.specs' '-T' './STM32N657xx.ld' '-L../../../Applications/NPU_Validation/../../../../Middlewares/ST/AI/Lib/GCC/ARMCortexM55' '-v' '-o' 'build/Project.elf' '-mlibarch=armv8.1-m.main+fp.dp+mve.fp' '-march=armv8.1-m.main+fp.dp+mve.fp' '-dumpdir' 'build/Project.elf.'
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/collect2.exe -plugin D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/liblto_plugin.dll -plugin-opt=D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/lto-wrapper.exe -plugin-opt=-fresolution=C:\Users\pil_1\AppData\Local\Temp\ccujNlfO.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc_nano -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc_nano --sysroot=D:\Stm32Cubbeide\STM32CubeIDE_1.16.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623\tools\bin\../arm-none-eabi -X -o build/Project.elf D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard/crti.o D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard/crtbegin.o D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard/crt0.o -L../../../Applications/NPU_Validation/../../../../Middlewares/ST/AI/Lib/GCC/ARMCortexM55 -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../arm-none-eabi/lib/thumb/v8-m.main+dp/hard -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1 -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib -LD:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../arm-none-eabi/lib build/Applications/NPU_Validation/Core/Src/main.o build/Applications/NPU_Validation/Core/Src/stm32n6xx_it.o build/Applications/NPU_Validation/Core/Src/md5.o build/Applications/NPU_Validation/Core/Src/system_clock_config.o build/Applications/NPU_Validation/Core/Src/misc_toolbox.o build/Applications/NPU_Validation/Core/Src/npu_cache.o build/Applications/NPU_Validation/Core/Src/mcu_cache.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbIO.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbMemRWServices.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiPbMgr.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiTestHelper.o build/Applications/NPU_Validation/X-CUBE-AI/App/aiTestUtility.o build/Applications/NPU_Validation/X-CUBE-AI/App/ai_device_adaptor.o build/Applications/NPU_Validation/X-CUBE-AI/App/lc_print.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_common.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_decode.o build/Applications/NPU_Validation/X-CUBE-AI/App/pb_encode.o build/Applications/NPU_Validation/X-CUBE-AI/App/stm32msg.pb.o build/Applications/NPU_Validation/X-CUBE-AI/App/network.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_cipher.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_dbgtrc.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_debug.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_lib.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_lib_sw_operators.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_rt_main.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_runtime.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_aton_util.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_sw_float.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ll_sw_integer.o build/Applications/NPU_Validation/../../../../Middlewares/ST/AI/Npu/ll_aton/ecloader.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/ai_wrapper_ATON.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/aiValidation_ATON.o build/Applications/NPU_Validation/X-CUBE-AI/atonn/ai_io_buffers_ATON.o build/Applications/NPU_Validation/Drivers/BSP/Components/aps256xx/aps256xx.o build/Applications/NPU_Validation/Drivers/BSP/Components/mx66uw1g45g/mx66uw1g45g.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_xspi.o build/Applications/NPU_Validation/Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_bus.o build/Applications/NPU_Validation/Drivers/CMSIS/Device/ST/STM32N6xx/Source/Templates/system_stm32n6xx_fsbl.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_bsec.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_cacheaxi.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_cortex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_gpio.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc_ex.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rif.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_uart.o build/Applications/NPU_Validation/Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_xspi.o build/startup_stm32n657xx.o -lc_nano -lm -lnosys -l:NetworkRuntime1010_CM55_GCC.a --wrap=malloc -Map=build/Project.map --cref --gc-sections --print-memory-usage --start-group -lgcc -lc_nano --end-group --start-group -lgcc -lc_nano --end-group D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard/crtend.o D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/thumb/v8-m.main+dp/hard/crtn.o -T ./STM32N657xx.ld
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-closer.o): in function `_close_r':
(.text._close_r+0xc): warning: _close is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-fstatr.o): in function `_fstat_r':
(.text._fstat_r+0xe): warning: _fstat is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-signalr.o): in function `_getpid_r':
(.text._getpid_r+0x0): warning: _getpid is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-isattyr.o): in function `_isatty_r':
(.text._isatty_r+0xc): warning: _isatty is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-signalr.o): in function `_kill_r':
(.text._kill_r+0xe): warning: _kill is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-lseekr.o): in function `_lseek_r':
(.text._lseek_r+0x10): warning: _lseek is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+dp/hard\libc_nano.a(libc_a-readr.o): in function `_read_r':
(.text._read_r+0x10): warning: _read is not implemented and will always fail
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: build/Project.elf has a LOAD segment with RWX permissions
D:/Stm32Cubbeide/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: build/Applications/NPU_Validation/Core/Src/main.o: in function `main':
D:/stm32edgeai/stedgeai/2.1/Projects/STM32N6570-DK/Applications/NPU_Validation/armgcc/../../../Applications/NPU_Validation/Core/Src/main.c:134: undefined reference to `in_0'
Memory region Used Size Region Size %age Used
AXISRAM1_S: 194512 B 1 MB 18.55%
collect2.exe: error: ld returned 1 exit status
make: *** [Makefile:276: build/Project.elf] Error 1
2025-07-15 5:12 AM
The error message from the compiler is
Applications/NPU_Validation/Core/Src/main.c:134: undefined reference to `in_0'This symbol is not in the original code (might be a part of code you added for debug purposes).
Could you fix the source code and retry ?
