Anamoly Detection using ISM330IS ISPU with STM32F40RE
Pan
Hello Everyone
I am trying to evaluate and demonstrate the ISM330IS ISPU with STM32F40RE Using nano edge AI. I am following this tutorial to move step by step   https://github.com/STMicroelectronics/st-mems-ispu/tree/master/tutorials/nanoedge_ai .  In Nano Edge AI after deployment and compilation of library when i import the Nano edge ai library into stm32cube IDE every things is ok . Unfortuntaely when i try to use Putty i am getting this message
ISPU NEAI Anomaly Detection Demo
Initialization
Not an N version.
Can anyone please suggest how i can resolve this issue.
Julian E.
Hello @Pan,
This error means that you are not using the version of the ISPU supported by NanoEdge.
But it seems that you cannot buy it anymore.
The correct version is: ISM330ISN (for example here: ISM330ISN STMicroelectronics | Mouser France)
I think that Mems studio is a better way to approach your problem than NanoEdge
Have a good day,
Julian
10 REPLIES 10
Julian E.
Hello @Pan,
Have a good day,
Julian
Hello Julian
Thanku very much for your quick response.
i have ordered the evaluation baord as exactly as mentioned on the ST website.
https://www.st.com/en/evaluation-tools/nucleo-f401re.html?icmp=tt31374_gl_lnkon_mar2023
https://www.st.com/en/ecosystems/x-nucleo-iks02a1.html?icmp=tt31374_gl_lnkon_mar2023
https://www.st.com/en/evaluation-tools/steval-mki230ka.html?icmp=tt31374_gl_lnkon_mar2023
Can you please tell me how i can get rid of this issue.
Thanku very much for your support and help.
@Pan,
I contacted the one who wrote this tutorial. I'll keep you updated.
Have a good day,
Julian
Hello Julian
Thanku very much for your response.
Can you please look at this version
https://www.st.com/en/evaluation-tools/steval-mki233ka.html#overview.
waiting for your update.
Thanku very much
Hello @Pan,
As you pointed, the board you need for NanoEdge is the STEVAL-MKI233KA , not the 230 ( STEVAL-MKI230KA).
The only one compatible with NanoEdge is the STEVAL-MKI233KA
Have a good day,
Julian
Hello Julian
Thanku very much for your response and confirmation.
Can you please provide me update about the tutorial as i am following this tutorial to implement anamoly detection in my project.
Sincerely Yours
@Pan,
In the tutorial it is indicated to use the STEVAL-MKI233KA and, apart from the visual which has changed with the different update of NanoEdge, everything else seems unchanged.
Let me know if you encounter any issue.
Have a good day,
Julian
Good Morning Julian
I have ordered the STEVAL-MKI233KA board, i will let you know if i have some issue.
Thanku very much
Pan
Hello Julian
Just want to confirm regarding the X-Nucleo-IKS01A3 board, currently this product is obsolete and i have ordered X-Nucleo-IKS4A1 Board as a substitute i hope it wont create any problem, just want to be sure from from your side as well.
Thanku very much for your suggestions
