2020-06-24 3:06 AM
2021-01-18 7:27 AM
Could you please verify that project build was successful completed ?
To verify that you navigate into your project and you should found the out.elf file under build directory, (see the attached example picture).
In case not built you must do it clicking on "Compile your application" available into "Common Task view".
After that you should able to burn on the target board and debug it.
Let me know.
Angelo
2021-01-18 7:27 AM
Let me know.
Angelo
2021-01-18 9:23 AM
Pretty sure in the preceding 7-months this has been resolved or the OP has moved on.
2021-01-18 9:34 AM
sorry for the delay. We will put more effort to satisfy any incoming request.
Let me know if you need more support.
Angelo
