Stellar E vs Stellar P for inverter
ay
Hello, I am interested in the Stellar E and P series for the purpose of motor control, with an inverter topology that has 12 independent switches and requires fine control of the offset between some of the waveforms.
1) The E series is marketed as optimized for traction inverters. Is there anything it can do in power converter applications that the P series cannot do? Does E series do something better or more easily, or just cheaper?
2) Is there any difference between the HR timer peripherals of the E and P series, except that E has 2 x 6 channels and P has 2 x 8?
3) How does the GTM4 of the P series compare to the advanced control timer of the E series? I can't find information about GTM4 on the product pages.
4) Is it correct that the E series does not have any interface for external RAM, not even quad SPI?
5) In the datasheet for E series, page 38, https://www.st.com/resource/en/datasheet/sr5e1e3.pdf, what is the meaning of the specification f_IN = 0.01 kHz minimum? Can it not convert the modulator output from an ADC such as AMC0336 if the analog input signal is DC?
Apologies, should I make a new thread for my questions about SR5?
Will the restrictions on SR6 information be lifted at some point in the future?
FSPIL
SR6 information is provided under NDA.
For any question, please contact local ST support, and do not post information/questions in this public forum.
Thank you.
