2022-09-16 6:04 AM
I recently bought SPC58NH-DISP board and I am trying to flash it using its USB interface but now I wonder if that is even possible since in the UDE config it points to JTAG interface and I have no clue on how to modify it if possible.
2022-09-16 6:13 AM
*Modified by moderation - please, keep the title shorter than 70 characters*
2022-09-16 8:17 AM
you need an UDE STICK from PLS to be able to program and debug through JTAG
Best regards.
2022-09-16 12:40 PM
thank you for your response, so the USB interface can not be used for programming ?
2022-09-16 1:16 PM
Do you have library or API code that can erase / write FLASH?
