Sr6p3e issue with Gicr module r/w
Safifi
I am using sr6p3e and I tried to access Gicr registers but I got aport exception, I tried several things like check if clock control the module and if there is a protection registers but I didn't find anything, I know that it use axim for interface so I tried to write on another module GTM registers after making necessary configuration but I got sameh issue
I check the startup code coming with mcal and found it configure mpu for Gicr and prephiral section and when I apply it in my code it solve the issue
I don't need to use mpu, is there another way to access Gicr and gtm ?
FSPIL
Hello Safifi,
SR6 products are still under NDA and can't be discussed in this public forum.
For any question, please contact your local ST support, and do not post information/questions in this public forum.
Thank you.
Best regards,
Francesco
