2021-06-25 8:08 AM
Could the BAF_BYPASS field in the BAF configuration DCF register by modified by the user.
If yes, under which module can I find it? I'm unable to find this in Lauterbach debugger.
If no, how can I skip the BAF section during the bootup? - My device has pre-programmed BAF region.
Thanks!
2022-05-06 6:18 AM
Hello ,
sorry for the late answer ,
in our team ,
i recommend to check this document and to add some addional commands in the cmm scripts
https://www2.lauterbach.com/pdf/debugger_mpc5500.pdf
Best Regards
Erwan
2022-05-06 6:18 AM
Hello ,
in our team ,
Best Regards
Erwan
