SPC58 data sharing between two cores
masterduff09
I've been using for a bit a SPC58 eval-board and i was wondering how to share global variables between the two cores. I searched around on the internet finding nothing useful. Is "volatile int" enough even for a rough and dirty data sharing or should I use something like SRAM and its shared memory location?
Erwan YVIN
Hello Mark ,
take a look in SPC58xNxx_RLA TripleCore Test Application for start
yes , volatile is not enough.
you should create a sort of shared SRAM in application.ld and define :
// Define shared variables in shared SRAM volatile int sharedvar __attribute__((section(".shared_sram")));
After checking , you should define a sort of SpinLock before accessing or writing it.
          Best regards
                      Erwan
4 REPLIES 4
Erwan YVIN
Hello Mark ,
          Best regards
                      Erwan
Hi Erwan,
thank you for answer.
How should I choose parameters for that section? I don't want to mess with already used memory partitions.
SPC58xNxx_RLA TripleCore Test Application does not implement data sharing between cores but only starting the additional cores and make the onboard LED blink. Are there any other sources from where I can get more info about this topic?
Thanks in advance, Mark
Erwan YVIN
Hello Mark ,
Sorry , we have no example.
You have no choice you should update your linker script copy application.ld  by user.ld
and try to create a shared ram data in user.ld
MEMORY { ........... shared_sram : org = tbd, len = 16k /* Define shared SRAM region */ ........... } SECTION { ....... .shared_sram : { . = ALIGN(4); *(.shared_sram) . = ALIGN(4); } > shared_sram .... }
   Best regards
              Erwan
Hello Mark,
I am working on a similar task of sharing data between two cores. Did this solution work for you? If so, were there any challenges you encountered while implementing this approach?
Thanks in advance,
Rohit.
