2024-12-18 9:20 PM
hello
I have just started working with SPC5 studio and I want to use PEMicro for debugging, but no matter how much I searched, I couldn't find anything that could help me in this way. My main problem is that I can't I set the software to PEMicro to debug with this programmer, and I read all the questions in this field that were asked on the site, but it did not help me. If there is a tutorial in this field, I would be happy if you could help, thank you.
2024-12-20 8:34 AM
Hello ,
I never tested PEmicro on SPC56/SPC57/SPC58.
it should work because MPC56/MPC57 is supported.
https://www.pemicro.com/forums/forum_topic.cfm?forum_id=8&forum_topic_id=7581
You should find PEmicro software and the eclipse plugins (Java11) associated.
gdb/gcc ppc gcc vle is already present in SPC5Studio tools suite.
You can use to associate your debug configuration.
Best Regards
Erwan
2024-12-20 8:34 AM
Hello ,
Best Regards
Erwan
