SPC5 studio PPCFREEGCC with VLE support version 4.9.2 Plugins.
‎2022-05-10 2:04 AM
Hello everyone,
I'm struggling trying to compile an old project without having to regenerate the configuration files, this project was made under the ppc freegcc with vle support V4.9.2 ,
I tried to compile using the last actual version(4.9.4) and I'm facing a lot of problems.
From what I understood in order to correctly compile we need a PATH that include 3 locations :
1-The Make.exe location
2-gcc.exe location (Plugins/GCC-plugin-version/toolchain/bin)
3-ld.exe location (Plugins/GCC-plugin-version/toolchain/powerpc-eabivle/bin)
Thing with using that version is that we will need to update the crt0.s file otherwise we will have linking errors, (I don't know if updating other s file is necessary)
Could someone please tell me how can I get the older version ? I'm just looking for that particular plugin<< com.st.tools.spc5.tools.gnu.gcc.ppcvle.win32_1.0.0.201611101103 >>
Thank you for you help.
‎2022-05-13 1:50 AM
ello CBena ,
we do not support anymore 4.9.2 on SPC5Studio.
I have recovered the version 4.9.2 on my configuration managment.
Could you provide to me by private message your email address ?
I will send to you a snapshot of Freegcc 4.9.2
Best regards
Erwan
‎2022-05-13 1:50 AM
ello CBena ,
Best regards
Erwan
