source code of SPI interface with TLE75008 ( it is an ic used to drive multiple relays)
PSING.2
5 REPLIES 5
Find something equivalent and port​
PSING.2
can i get SOURCE CODE FOR SPI Module in SPC5 STUDIO ARM PROCESSOR
SPC5 SPI example
https://www.st.com/content/ccc/resource/sales_and_marketing/presentation/product_presentation/9f/1e/49/97/37/fb/4b/e7/SPC5%20Connect%20-%20Getting%20Started.pdf/files/SPC5%20Connect%20-%20Getting%20Started.pdf/jcr:content/translations/en.SPC5%20Connect%20-%20Getting%20Started.pdf
https://community.st.com/s/question/0D50X00009Xkgq4SAB/solved-spi-slave-configuration-for-spc56el
SPC5 Discovery
https://www.st.com/en/evaluation-tools/spc56d-discovery.html
I believe the SPC5Studio should install/provide an number of sample projects and examples.
If not work with your local sales office, or find those offering training and consultant services for these parts.
PSING.2
could you please send me the sample code for SPI protocol in master mode, using hardware slave.
CSN or chip select pin is not getting LOW. we configured it as WPS pull down & WPE disabled.
