2017-11-09 11:07 PM
what is serial driver exactly? Role of serial driver? and how it works for GSM M66 module.
2017-11-10 1:08 AM
Hello Soni ,
the serial driver is very useful to communicate with a GSM modem by AT Command.
you need :
in our past projects (university), GSM modem (Near Space Balloon) and Bluetooth modem (Manual kit car) has been plugged without any issue.
Best Regards
Erwan
2017-11-10 1:08 AM
Hello Soni ,
you need :
Best Regards
Erwan
2017-11-10 2:00 AM
Thanks Erwan,
but i am not fully satisfied with your anwer.
I used LIN0RX/LIN0TX(&SD1), found pins which are PB2 & PB3 in case of Dline. but want to know how serial driver play in serial communication. I already sent AT commands on M66 board(GSM), but want to know the role of serial driver.
please elaborate again.
2017-11-10 3:22 AM
2017-11-10 3:25 AM
Thank you.
