Problem to create SPC5 application without RLA component at version 5.8
Cengizhan SAY?ILI
I changed my pc and install SPC5Studio 5.8. After installation i want to create application without RLA platforms. But there are only RLA platforms. How can i fix this problem.
Because all project developed without RLA. Also i can not install SPC5 HAL. I need this component also.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
3 REPLIES 3
Erwan YVIN
Hello ,
the update site has been splited
You can find the HAL in the following update site
http://community.spc5studio.com
please go to http://download.spc5studio.com/updates for more information
Best regards
Erwan
Cengizhan SAY?ILI
I try to install HAL and i retrieve this error message. Every installation, i got same message. Is there any suggestion.
An error occurred while collecting items to be installed
session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.st.tools.spc5.wizard.pinmap,1.0.4.201807261518
No repository found containing: osgi.bundle,com.st.tools.spc5.wizard.pinmap.spc5,1.0.4.201807261518
No repository found containing: osgi.bundle,com.st.tools.spc5.wizard.pinmap.spc570sxx,1.0.1.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc560bcxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc560bxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc560dxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc560pxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc563mxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc564axx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc56ecxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc56elxx,1.0.0.201807261518
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.build.spc570sxx,1.0.0.201807261518
.... go on
Erwan YVIN
Hello Cengizhan ,
Please follow http://download.spc5studio.com/updates
if you want to install HAL on SPC5Studio 5.8.1
You have to add the 2 updates sites in the update site list in SPC5Studio
there are some dependencies
Best regards
Erwan
