I have a question about how to use the SPC560P microcontroller evaluation board.
TNAOH.1
I have purchased the SPC560P microcomputer evaluation board (SPC560P-DISP).
I want to use SPC5studio and SPC5-UDESTK.
However, "Activation-Key" is required to get SPC5-UDESTK.
SPC5-UDESTK website: www.pls-mc.com/spc5-udestk
The input form has the following descriptions.
[Please insert the activation key you got from STMicroelectronics in the from XXXXXXXX-XXXX-XXXX-XX]
What is "Activation-Key"?
Please tell me how to get it.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
hello ,
It is in the link that you have provided (limited to 256K)
The starterkit version of SPC5-UDESTK-EVAL can be used for evaluation purposes without registration. In this case, the SPC5-UDESTK-EVAL is restricted to a limited code size for downloading of 256 kBytes.
For that please use starterkit keys:
  • SPC5-UDESTK-EVAL version 4.10.xx:
    • SPC56x: 6JD674I4BFJ9MQDIB4IR
    • SPC57x/SPC58x: 2FCRJ7E6OP7ECOHJCOPR (multi-core architectures).
  • SPC5-UDESTK-EVAL version 5.0.xx:
    • SPC56x: 1MEFHOC37GSE7OSF7OE6
    • SPC57x/SPC58x: 6JDMN5I4B7JDMQ9MR4IF (multi-core architectures).
Add this keys into UDE License Manager (Menu Help - License Manager - Add Key ).
if you want to the full version, you have to fill the form.
Best regards
Erwan
1 REPLY 1
Erwan YVIN
hello ,
Best regards
Erwan
