2020-07-10 4:49 AM
How to add postbuild steps file like srecord ?
Thanks for your attention,
Best regards.
2020-10-01 11:50 PM
actually the generation of S-Record format is already available in SPC5Studio
and is enabled by default.
Check the build directory and look for ".mot" files.
Giuseppe
2020-08-20 2:27 AM
Hello ,
you can add some post-build options in the properties in the project
do not forget to update user.mak
html: real-html
do-post-build-stuff
pdf: real-pdf
do-post-build-stuff
txt: real-txt
do-post-build-stuff
Best regards
Erwan
2020-10-01 11:50 PM
Giuseppe
